[Qgis-community-team] Transifex updates
Tim Sutton lists at linfiniti.com
Fri Mar 22 05:29:36 PDT 2013
Hi All
On Fri, Mar 22, 2013 at 10:47 AM, Otto Dassau <dassau at gbd-consult.de> wrote:
8<---------------------snip--------
>> First I generated them from Master, and then from 1.8, updating /
>> overwriting the ones pushed from master. Perhaps I should flush all
>> files and push them up again with the amendment that I include the
>> version number in the resource name so transfiex would list them as
>> e.g. v1.8-Introduction.po
>> Then we could use the versions feature of transifex to identify all
>> the po files for 1.8 and we could also provide for simultaneous
>> translations of 1.8 and 2.
>> If it doesnt cause any invonvenience to others (please let me know if
>> you think it will), I will do this today (friday).
>> Regards
>> Tim
> Good idea, I think this would be great! If anyone wants to complain, please
> do it now ;).
> Thanks a lot Tim
I have created a transifex release and tagged all the resources in 1.8
accordingly. The release is visible here:
https://www.transifex.com/projects/p/qgis-documentation/r/1-8/
I am busy pushing the po files up for the release version - it would
be great if you could all do the same cross checking to see if
everything is as expected. Your workflow woould then need to be
updated to edit only the files in the transifex release. I will make
another 2-0 release resource set which will correspond to the files in
master.
Note: the tx push is still underway - it may take an hour or two more....
Regards
Tim
> Regards
> Otto
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
More information about the Qgis-community-team mailing list
