[Qgis-community-team] Transifex updates
Otto Dassau dassau at gbd-consult.de
Fri Mar 22 05:36:51 PDT 2013
Hi Tim,
Am Fri, 22 Mar 2013 14:29:36 +0200
schrieb Tim Sutton <lists at linfiniti.com>:
> Hi All
> On Fri, Mar 22, 2013 at 10:47 AM, Otto Dassau <dassau at gbd-consult.de>
> wrote:
> 8<---------------------snip--------
> >> First I generated them from Master, and then from 1.8, updating /
> >> overwriting the ones pushed from master. Perhaps I should flush all
> >> files and push them up again with the amendment that I include the
> >> version number in the resource name so transfiex would list them as
> >> e.g. v1.8-Introduction.po
> >> Then we could use the versions feature of transifex to identify all
> >> the po files for 1.8 and we could also provide for simultaneous
> >> translations of 1.8 and 2.
> >> If it doesnt cause any invonvenience to others (please let me know if
> >> you think it will), I will do this today (friday).
> >> Regards
> >> Tim
> > Good idea, I think this would be great! If anyone wants to complain,
> > please do it now ;).
> > Thanks a lot Tim
> I have created a transifex release and tagged all the resources in 1.8
> accordingly. The release is visible here:
> https://www.transifex.com/projects/p/qgis-documentation/r/1-8/
> I am busy pushing the po files up for the release version - it would
> be great if you could all do the same cross checking to see if
> everything is as expected. Your workflow woould then need to be
> updated to edit only the files in the transifex release. I will make
> another 2-0 release resource set which will correspond to the files in
> master.
> Note: the tx push is still underway - it may take an hour or two more....
> Regards
> Tim
ok, this means, we have to stop committing files translated with linguist
etc and only use transifex from now on?
And what if we make changes to the english master document. Is it necessary
to use some special tool also, or can we just use a normal editor as we did
so far and commit our changes to master? Will it be updated in the 2-0
release resource automatically?
Regards
Otto
More information about the Qgis-community-team mailing list
