[Qgis-community-team] icons not showing
Alexandre Neto senhor.neto at gmail.com
Thu Nov 20 16:13:11 PST 2014
Hello Ramon,
The names inside the pipe characters are called substitutions, and they
don't have necessarily the same name as the image files they pretend to
show.
The list of substitutions is in the conf.py file in the source folder. Make
sure that there is a line for each one of those icons.
Best regards,
Alexandre Neto
Em 20/11/2014 22:22, "Ramon Andiñach" <custard at westnet.com.au> escreveu:
> Hi,
> I'm having a problem with a couple of icons in the print_composer.rst file.
> A couple of days back I noticed that there was space left for the icons
> for locked and unlocked layers in
> http://docs.qgis.org/testing/en/docs/user_manual/print_composer/print_composer.html#table-composer-1
> I worked out that the relevant files are called locked.png and
> unlocked.png and added them into the table as |locked| and |unlocked|. That
> day the text I entered showed up, but no icons - so I just assumed that the
> icons were missing.
> I've since discovered that the icons are in resources/en/docs/common/ so
> I'm at a loss as to why they're not showing up.
> Does anyone have some pointers?
> -ramon.
> Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20141121/fc2d0e8a/attachment.html>
More information about the Qgis-community-team mailing list
