[Qgis-community-team] icons not showing
Ramon AndiƱach custard at westnet.com.au
Thu Nov 20 21:50:52 PST 2014
Thanks Alexandre, that's the pointer I needed. Icons are now visible.
-ramon.
> On 21 Nov 2014, at 8:13, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Hello Ramon,
> The names inside the pipe characters are called substitutions, and they don't have necessarily the same name as the image files they pretend to show.
> The list of substitutions is in the conf.py file in the source folder. Make sure that there is a line for each one of those icons.
> Best regards,
> Alexandre Neto
> Em 20/11/2014 22:22, "Ramon Andiñach" <custard at westnet.com.au> escreveu:
>> Hi,
>> I'm having a problem with a couple of icons in the print_composer.rst file.
>> A couple of days back I noticed that there was space left for the icons for locked and unlocked layers in http://docs.qgis.org/testing/en/docs/user_manual/print_composer/print_composer.html#table-composer-1
>> I worked out that the relevant files are called locked.png and unlocked.png and added them into the table as |locked| and |unlocked|. That day the text I entered showed up, but no icons - so I just assumed that the icons were missing.
>> I've since discovered that the icons are in resources/en/docs/common/ so I'm at a loss as to why they're not showing up.
>> Does anyone have some pointers?
>> -ramon.
>> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
>> Qgis-community-team at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20141121/14e27bbf/attachment.html>
More information about the Qgis-community-team mailing list
