[Qgis-community-team] Proposal to divide some pages in QGIS documentation
Richard Duivenvoorde richard at duif.net
Sun Jun 7 11:31:26 PDT 2015
it's a good thing, to split up and make docs better \o/
one thing to note, is that this will also mean (partly) new resources in
transifex. The synchronisation between the sources/files in github and
transifex is still by hand. So please let me know when you want a
'synchronisation/update'.
another thing to know/note is that if we create a new file (and we add
it as a resource), it is automatically pushed to transifex, BUT old (not
nessecary) files will NOT be removed automatically.
so please let us/me know if you find a resource at transifex, of which
you cannot find a file in the documentation website anymore. We should
then remove the resource.
BUT we have to be carefull with removing, because removing a 'resource'
will also remove all translations. And I'm not sure (yet) that from a
removed resource we keep th 'translation memory' to be able to use for
(the same) strings in newer or renamed resources.
( just a heads up, so you all know how things work, and we can refine
and make translations better :-)  )
Regards,
On 07-06-15 16:16, Yves Jacolin wrote:
> Le samedi 6 juin 2015, 01:22:26 DelazJ a écrit :
>> Hi Folks,
>> While reading QGIS documentation, there are some pages that leave me
>> puzzled. You may have a look at Print Composer [1], vector properties
>> dialog [2] pages.
>> IMHO, these pages are too long. For the reader, scrolling can become
>> tedious while looking for a precise information. Sure, the subject is wide
>> and there is a lot of informations at these pages but I think that, because
>> subject is wide, it can be splited into several pages, shorter, more
>> precise and readable. As there are Previous/Next buttons, skipping sections
>> while reading can easily be done.
>> From writer side, I think that having short (and specialized) page helps us
>> to quickly identify where there may be a lack of documentation, easily
>> update or improve them...
>> So, few days ago, I made a pull request [3] that splits Print Composer
>> chapter into many pages, reorganizing sections and sequences.
>> If you agree with the spliting principle of these chapters, can some
>> documentation writers review it, amend it and let me know if it is ok? It's
>> the first time I use rst files so it'd be nice if someone can review my PR
>> before I begin spliting vector properties chapter.
>> Regards,
>> Harrissou
>> [1]
>> http://docs.qgis.org/2.8/fr/docs/user_manual/print_composer/print_composer.h
>> tml [2]
>> http://docs.qgis.org/2.8/fr/docs/user_manual/working_with_vector/vector_prop
>> erties.html [3] https://github.com/qgis/QGIS-Documentation/pull/544/
> DelazJ,
> My opinions is that your split is perfect. As you said all in one page should
> be too much and the split is great.
> One more feedback (with my comments in you Pr): the index page contains only a
> toc, do you think we can add a small paragraph to introduce the composer
> chapter? As the one in "First Steps" section for instance?
> Otherwise just merge.
> Y.
More information about the Qgis-community-team mailing list
