[Qgis-developer] Re: Labels in OS X
John C. Tull john.tull at wildnevada.org
Fri Jul 11 14:16:44 EDT 2008
I was building with several options, including nomake-demos! I'm going
to rebuild Qt today without any configure args and then report back.
Thanks for the suggestions.
On Jul 11, 2008, at 9:53 AM, Tom Elwertowski wrote:
> The only parameter I use with Qt configure is -universal. Is text
> being truncated in the demo and example apps that come with Qt? This
> would determine if the problem is in Qt or qgis.
> Next I would check what string is extracted from the feature at
> QgsLabel::renderLabel line 106. You can work forward or backward
> from this point depending upon whether or not you see the full string.
> Tom
> John C. Tull wrote:
>> Thanks for the test. I just cannot think what is causing my
>> problems with labels on the canvas... Care to share your Qt
>> configure arguments? Maybe there's a problem there, although I
>> tried the binary installer as well as home-rolled with the same
>> label problem in either situation.
>> Cheers,
>> John
>> On Jul 9, 2008, at 11:30 PM, Tom Elwertowski wrote:
>>> John,
>>> Labels work for me using current svn, Qt 4.4.0 and OS X 10.5.4. I
>>> don't use Python. Trying to match your example, all I did was
>>> select a label field in the Vector Layer Properties dialog and
>>> check Buffer Labels.
>>> Tom
>>> John C. Tull wrote:
>>>> Tom,
>>>> I was wondering if you have been seeing problems with labels in
>>>> qgis using qt-4.4.0, pyqt-4.4.2? Below is an example of how my
>>>> labels are being truncated to rightmost characters in the map
>>>> canvas. It seems to be something like a 50% truncation, so long
>>>> labels show more characters than short labels, but everything is
>>>> being cut short.
>>>> Someone on irc and linux with qt-4.4.0 did not have this problem,
>>>> so I am trying to see if this is happening with other Mac users.
>>>> I have built the most current svn, am on 10.5.4, and seemed to
>>>> only have this problem after upgrading Qt.
>>>> Regards,
>>>> John
