[Qgis-developer] ogr virtual datasource not working
Milo van der Linden milo at dogodigi.net
Wed Feb 23 11:03:01 EST 2011
Hi all,
I have a csv file (which is public domain and can be found here:
http://www.dogomaps.net/bikkels/test.csv) that I try to access through a vrt
(virtual datasource http://www.dogomaps.net/bikkels/test.vrt). It is
accessible with ogrinfo, but when I try to open it with qGIS, it fails.
ogrinfo output looks valid. What can be wrong?
miblon at miblon-K52N:~/test$ ogrinfo -so test.vrt test
INFO: Open of `test.vrt'
      using driver `VRT' successful.
Layer name: test
Geometry: Point
Feature Count: 63016
Extent: (0.000000, 0.000000) - (133.426000, 494.857000)
Layer SRS WKT:
PROJCS["Amersfoort / RD New",
    GEOGCS["Amersfoort",
        DATUM["Amersfoort",
            SPHEROID["Bessel 1841",6377397.155,299.1528128,
                AUTHORITY["EPSG","7004"]],
            AUTHORITY["EPSG","6289"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.01745329251994328,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4289"]],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    PROJECTION["Oblique_Stereographic"],
    PARAMETER["latitude_of_origin",52.15616055555555],
    PARAMETER["central_meridian",5.38763888888889],
    PARAMETER["scale_factor",0.9999079],
    PARAMETER["false_easting",155000],
    PARAMETER["false_northing",463000],
    AUTHORITY["EPSG","28992"],
    AXIS["X",EAST],
    AXIS["Y",NORTH]]
Incident Id: String (0.0)
Nr Incident: String (0.0)
Dtg Start Incident: String (0.0)
Dtg Einde Incident: String (0.0)
Brw Melding Cl: String (0.0)
Brw Melding Cl1: String (0.0)
Brw Melding Cl2: String (0.0)
Naam Locatie1: String (0.0)
Postcode4pp: String (0.0)
Plaats Naam: String (0.0)
Gemeente Naam: String (0.0)
T X Coord Loc: String (0.0)
T Y Coord Loc: String (0.0)
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110223/0323596d/attachment.html
