[Qgis-developer] QGIS 3 master available in OSGeo4W! Youhou....
Nyall Dawson nyall.dawson at gmail.com
Mon Feb 6 15:09:12 PST 2017
On 7 February 2017 at 02:48,  <gordon at shieldaig.com> wrote:
> That is wonderful news for the Windows version.
> In case I missed something, my understanding is that qgis-dev (2.99) builds
> and works on Ubuntu 16.04 64-bit, running Qt 5.5, Grass 7, Python 3.5, etc..
> But doesn't build on Ubuntu 16.10 which uses Qt 5.6.
> And most certainly
> doesn't build with Qt 5.8 or 5.7 even without Qt Webkit and WebkitWidgets.
That's not the case - I regularly build on both Ubuntu 16.10 and
Fedora 25 (qt 5.7.1). On both platforms Qt Webkit is working
correctly.
Are you using Qt from the distro's repos or the binaries provided by
the Qt project?
Nyall
> The Qt Webkit and Q WebkitWidgets are available for Ubuntu but one of the
> requirements is an upgrade of "icu" to "icu4c-58_2".  Has anyone installed
> all that and tried it?  Knows what changes are required?  Possibly the build
> requires a lower version of g++ from 6.3 but I tried g++-5 and that made no
> difference and making too many changes to Qt header files seemed risky.
> Gordon
> On 2017-02-06 06:20, DelazJ wrote:
>> Hi all,
>> My daily update of osgeo4w installed today qgis-dev (2.99), meaning
>> that qgis 3 dev can now be easily installed (and tested?) on Windows.
>> Wonderful!
>> Big thanks to you, Jüergen
>> Regards,
>> Harrissou
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
