[Qgis-developer] Dropping the "render" checkbox
Tim Sutton
tim at kartoza.com
Tue Feb 28 01:42:01 PST 2017
Hi
On Tue, Feb 28, 2017 at 10:43 AM, Martin Dobias <wonder.sk at gmail.com> wrote:
> Yeah that's one of the things I wanted to improve within MTR, but
> didn't get to it yet - it would definitely make the render flag less
> interesting. And the same thing could be done also for labeling - only
> switch to the newly computed labeling when it is finished.
> As Nyall said in the first mail, if you need to use the render flag,
> then there is some problem with rendering - so knowing cases when
> people still use it is very useful as we can make QGIS behave nicely
> without the need for render checkbox! So please keep posting your use
> cases :-)
One reason to keep it: For us the use case has often been when you are
doing first set up of a project and you are dropping a bunch of large
layers yet. You want to set up scale dependent visibility and rules first
without waiting for time consuming renders, then enable rendering when
everything is added. I know we can also use the option to make layers not
visible when they are first added to the canvas so I reckon that use case
can be worked around easily enough,
One reason to remove it: I have often done training courses where a user
has randomly unchecked that and they can't figure out why nothing draws. In
a training room that is easy to fix. In 'the wild' I bet it is a source of
big frustration....
We could also have a behaviour like holding shift down when adding a layer
to the canvas makes the layer visibility turn off in the legend....though
it probably still won't help Denis' use case.....
Regards
Tim
> Cheers
> Martin
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
Visit http://kartoza.com to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Tim is a member of the QGIS Project Steering Committee
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170228/cb6726a9/attachment.html>
