[Qgis-developer] Processing tests for gdal:extractprojection -> no output file
matteo matteo.ghetta at gmail.com
Thu Jan 12 06:18:04 PST 2017
Hi Matthias,
thanks for the complete answer.
However I added the qgis:createspatialindex algorithm that does not
produce any output (but it is still "linked" to the input layer) and the
test runs fine with the parameter
result: {}
in this way I thought it is possible to check the output (without
testing it) but testing the algorithm itself, i.e. the algorithm runs
fine and creates the output.
Thanks again for the availability
Cheers
Matteo
