[Qgis-developer] Processing tests for gdal:extractprojection -> no output file
Matthias Kuhn matthias at opengis.ch
Thu Jan 12 07:03:32 PST 2017
Hi Matteo,
Not sure if I can follow, was that another question?
Adding a simple "smoke test" for createspatialindex sounds fine. One
that does not check results but rings the alarm if an exception is thrown.
In the case of extractprojection that would work as well of course.
But if you are at it already, I think it's better to do things properly.
I think there is a html file created which could be
* checked for correctness in a test
* and potentially used as input for other algorithms
so I think that's a different case and it should be fairly simple to fix
the algorithm.
Best
Matthias
On 01/12/2017 03:18 PM, matteo wrote:
> Hi Matthias,
> thanks for the complete answer.
> However I added the qgis:createspatialindex algorithm that does not
> produce any output (but it is still "linked" to the input layer) and the
> test runs fine with the parameter
> result: {}
> in this way I thought it is possible to check the output (without
> testing it) but testing the algorithm itself, i.e. the algorithm runs
> fine and creates the output.
> Thanks again for the availability
> Cheers
> Matteo
