[Qgis-developer] Proposal - Change mIconProjectionEnable/Disable Icons
Nyall Dawson nyall.dawson at gmail.com
Sun Jan 15 16:31:32 PST 2017
On 16 January 2017 at 10:27, Tim Sutton <tim at kartoza.com> wrote:
> Hi
> On 16 Jan 2017, at 7:11 AM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> What about a cross out though the icon, to show not enabled?
> When I was originally working on on the fly projection support a long time ago I added that icon so you could en/disable OTF in case OTF had some side effects. Many years have passed and I would guess there isn't much reason to ever have OTF disabled. Does anyone still have a use case for this? If not, why don't we just make it permanently enabled? And then use the project properties icon in greyscale down in the status bar (which I still find pretty convenient to have there).
Big +1, for these reasons:
- OTF off results in confusing and often misleading measurements - see
https://github.com/qgis/QGIS/pull/3992
- There's no performance penalty associated with OTF when no
transformation is required - everything is short cut so no projection
is done
- If user's really want to display a layer in a different CRS to what
the layer has, they should just manually select a new CRS for that
layer in layer properties.
Nyall
> Regards
> Tim
> On Mon, Jan 16, 2017 at 10:10 AM, Alexandre Neto <senhor.neto at gmail.com> wrote:
>> Mathieu Pellerin <nirvn.asia at gmail.com> escreveu no dia segunda, 16/01/2017 às 00:04:
>>> +1 on updating the icon, -1 to introducing color icon in the status bar.
>> Point taken. No colors
>>> On Jan 16, 2017 06:56, "Alexandre Neto" <senhor.neto at gmail.com> wrote:
>>>> Proposal: for consistency, change the current mIconProjectionEnable and mIconProjectionDisable Icons. These are the Icons next to the EPSG code
>>>> Rationale: While converting those icons from PNG to SVG, I could not understand what they were, or try to represent. Besides, these buttons open the CRS tab in project properties, which uses another Icon (CRS.svg). So, for consistency and user's recognition, it would be better to use always the same icon when we are referring to select a CRS.
>>>> My idea is to use the CRS.svg icon as a base to create a version for enable/disable icons that look good at 16x16 pixels.
>>>> http://imgur.com/O7hKsmK
>>>> I would also replace the Icon in the capture coordinates plugin, which is the same.
>>>> Any objections to this?
>>>> Alexandre Neto
>>>> Alexandre Neto
>>>> @AlexNetoGeo
>>>> http://sigsemgrilhetas.wordpress.com
>>>> http://gisunchained.wordpress.com
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Alexandre Neto
>> @AlexNetoGeo
> Tim Sutton
> Co-founder: Kartoza
> Project chair: QGIS.org
> Visit http://kartoza.com to find out about open source:
> Desktop GIS programming services
> Geospatial web development
> GIS Training
> Consulting Services
> Skype: timlinux
> IRC: timlinux on #qgis at freenode.net
> Kartoza is a merger between Linfiniti and Afrispatial
