[QGIS-Developer] Processing R scripts - TypeError: cannot concatenate 'str' and 'NoneType' objects
Anita Graser anitagraser at gmx.at
Sat Jun 3 03:36:49 PDT 2017
Maybe a fix ...
On Fri, Jun 2, 2017 at 8:31 PM, Anita Graser <anitagraser at gmx.at> wrote:
> File "C:/OSGEO4~1/apps/qgis-ltr/./python/plugins\processing\algs\r\RAlgorithm.py",
> line 404, in getExportCommands
> commands.append('cat("##' + out.name + '",file="' + outputDataFile +
> '",sep="\n",append=TRUE)')
​Not sure if it breaks anything else, but if I add
​            elif isinstance(out, OutputHTML):
                pass
before the offending
            elif out.name != RAlgorithm.R_OUTPUT_VALUES:
outputDataFile + '",sep="\n",append=TRUE)')
                commands.append('cat(' + out.name + ',file="' +
Then the HTML output is created and visible in the results viewer and there
is no error.
I'm not sure what the problematic lines were supposed to do anyway ...
Best wishes,
Anita
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170603/56d22546/attachment.html>
More information about the QGIS-Developer mailing list
