[QGIS-Developer] Processing R scripts - TypeError: cannot concatenate 'str' and 'NoneType' objects
Giovanni Manghi giovanni.manghi at gmail.com
Mon Jun 5 03:09:45 PDT 2017
I confirm that in previous QGIS releases (2.14/2.16 for example) R
scripts were working as expected.
So I added
https://issues.qgis.org/issues/16618
to the list of regressions that must be fixed in time for the next LTR
https://docs.google.com/spreadsheets/d/1frZQU8bwGX499WMvtOc6GDIWqEuSv3QHz3zc90TS46Q/edit?usp=sharing
cheers!
-- G --
> Maybe a fix ...
> On Fri, Jun 2, 2017 at 8:31 PM, Anita Graser <anitagraser at gmx.at> wrote:
>> File "C:/OSGEO4~1/apps/qgis-ltr/./python/plugins\processing\algs\r\RAlgorithm.py",
>> line 404, in getExportCommands
>> commands.append('cat("##' + out.name + '",file="' + outputDataFile +
>> '",sep="\n",append=TRUE)')
> Not sure if it breaks anything else, but if I add
>             elif isinstance(out, OutputHTML):
>                 pass
> before the offending
>             elif out.name != RAlgorithm.R_OUTPUT_VALUES:
> outputDataFile + '",sep="\n",append=TRUE)')
>                 commands.append('cat(' + out.name + ',file="' +
> Then the HTML output is created and visible in the results viewer and there
> is no error.
> I'm not sure what the problematic lines were supposed to do anyway ...
More information about the QGIS-Developer mailing list
