[QGIS-Developer] Postgis loading using COPY instead of INSERTS?
Matthias Kuhn
matthias at opengis.ch
Sat Jun 10 12:49:01 PDT 2017
On 6/10/17 8:55 PM, Régis Haubourg wrote:
> 2017-06-10 14:17 GMT+02:00 Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>>:
> > I'd estimate 90+% of the time we are bulk adding features we don't
> > care about the updated feature ids, and it's only when adding small
> > amounts of features that this updated id is used. Definitely for
> > things like QgsVectorLayerExporter it's not required, so we'd
> get the
> > COPY speed boost used.
> > Thoughts?
> Thanks for that!
> In edit mode, except for copy-paste , I don't really see where we
> could benefit from COPY instead of atomic INSERTS. What are the other
> use cases for batch insert deserving a COPY boost?
> This would also help fixing https://issues.qgis.org/issues/16552
> <https://issues.qgis.org/issues/16552>
> Sounds like a good idea to me
> It seems fixed by Jurgen in fact :)
Views created with the DB manager work now, but the related issue
https://issues.qgis.org/issues/16083 still persists.
Something else to discuss is what will be sent along with the
`featureAdded(QgsFeatureId fid)` signal if the id is generated on the DB
but not propagated back to the client.
Matthias
> Régis
> Matthias
> > Nyall
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.or
> <mailto:QGIS-Developer at lists.osgeo.org>
> g <mailto:QGIS-Developer at lists.osgeo.org>
> > List info:
> https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> > Unsubscribe:
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170610/bbc927ba/attachment.html>
