[QGIS-Developer] Postgis loading using COPY instead of INSERTS?
Nyall Dawson nyall.dawson at gmail.com
Sat Jun 10 15:04:56 PDT 2017
On 11 June 2017 at 05:49, Matthias Kuhn <matthias at opengis.ch> wrote:
> Something else to discuss is what will be sent along with the
> `featureAdded(QgsFeatureId fid)` signal if the id is generated on the DB but
> not propagated back to the client.
I don't think this is a big limitation - we just note it in the docs
for the fast insert flag that featureAdded won't be emitted. It's only
emitted when adding to a vector layer anyway, and most of the cases
where the fast insert flag will be used will be adding directly to a
data provider.
Nyall
More information about the QGIS-Developer mailing list
