[Qgis-developer] Plugin with custom QGIS-Qt Widget for master
Raymond Nijssen r.nijssen at terglobo.nl
Sun Mar 5 23:42:42 PST 2017
Hi Matteo,
I ran into this last week. The solution, or workaround, is here:
https://lists.osgeo.org/pipermail/qgis-developer/2016-August/044138.html
You need to manually change the output of QtDesigner.
Good luck!
Raymond
On 06-03-17 07:07, Denis Rouzaud wrote:
> Hi Matteo,
> Are you using a compiled UI file or the UI directly?
> Can you point to the source online?
> Denis
> Le dim. 5 mars 2017 à 22:35, matteo <matteo.ghetta at gmail.com
> <mailto:matteo.ghetta at gmail.com>> a écrit :
>     sorry, the error related to the widget is:
>       File
>     "/home/matteo/lavori/QGIS/build-qgis33/output/python/qgis/utils.py",
>     line 647, in _import
>         mod = _builtin_import(name, globals, locals, fromlist, level)
>     ImportError: No module named 'qgsmaplayercombobox'
>     Matteo
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Terglobo
Fahrenheitstraat 1
5223 BJ 's-Hertogenbosch
06 25 31 49 83
