[Qgis-developer] Plugin with custom QGIS-Qt Widget for master
Luigi Pirelli
luipir at gmail.com
Mon Mar 6 01:31:15 PST 2017
Hi Raymond
in Qt (AFAIR) you can specify the include of the custom UI, so the
overwrite will be avoided.
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 6 March 2017 at 08:42, Raymond Nijssen <r.nijssen at terglobo.nl> wrote:
> Hi Matteo,
> I ran into this last week. The solution, or workaround, is here:
> https://lists.osgeo.org/pipermail/qgis-developer/2016-August/044138.html
> You need to manually change the output of QtDesigner.
> Good luck!
> Raymond
> On 06-03-17 07:07, Denis Rouzaud wrote:
>> Hi Matteo,
>> Are you using a compiled UI file or the UI directly?
>> Can you point to the source online?
>> Denis
>> Le dim. 5 mars 2017 à 22:35, matteo <matteo.ghetta at gmail.com
>> <mailto:matteo.ghetta at gmail.com>> a écrit :
>> sorry, the error related to the widget is:
>> File
>> "/home/matteo/lavori/QGIS/build-qgis33/output/python/qgis/utils.py",
>> line 647, in _import
>> mod = _builtin_import(name, globals, locals, fromlist, level)
>> ImportError: No module named 'qgsmaplayercombobox'
>> Matteo
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Terglobo
> Fahrenheitstraat 1
> 5223 BJ 's-Hertogenbosch
> 06 25 31 49 83
