[Qgis-developer] Ideas concerning plugin deployment
Matthias Kuhn matthias at opengis.ch
Mon Mar 13 01:26:18 PDT 2017
Hi Magnus,
we use a release script in QFieldSync, where we directly release from
travis when a new tag pushed and tests run successfully (and some other
conditions like tag name matches the version in metadata etc. are met).
https://github.com/opengisch/qfieldsync/blob/master/.travis.yml#L27
It also only packages a sub-folder with the plugin, so scripts for ci
etc that live outside this folder are not packaged.
Hope that helps :)
Matthias
On 03/11/2017 10:12 PM, Magnus Homann wrote:
> Hello, currently I tag my plugin code in git, and extract and build a
> zip-file which is uploaded to plugin repo.
> The Makefile that plugin_builder is supplyng, also have an option to zip
> locally deployed files for later upload.
> I prefer to packaged directly from tag in git, but then every file that
> is in git will be packaged!
> Have anyone made a mixed approach, packaging directly from a git tag,
> but only a sub-set of the files?
> /Magnus
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
