[Qgis-developer] Ideas concerning plugin deployment
Tom Kralidis tomkralidis at gmail.com
Mon Mar 13 04:49:11 PDT 2017
In MetaSearch we have a release workflow for 'out-of-band' releases
from QGIS core which was inherited from when MetaSearch was not a core
QGIS plugin.
MetaSearch uses Paver to generate a zipfile for upload to plugins.qgis.org [1].
You can see the core machinery to generate the zipfile at [2].
Hope this helps.
..Tom
[1] https://github.com/qgis/QGIS/blob/master/python/plugins/MetaSearch/pavement.py#L138
[2] https://github.com/qgis/QGIS/blob/master/python/plugins/MetaSearch/pavement.py#L106
On Mon, 13 Mar 2017, Matthias Kuhn wrote:
> Date: Mon, 13 Mar 2017 09:26:18 +0100
> From: Matthias Kuhn <matthias at opengis.ch>
> To: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Ideas concerning plugin deployment
> Hi Magnus,
> we use a release script in QFieldSync, where we directly release from
> travis when a new tag pushed and tests run successfully (and some other
> conditions like tag name matches the version in metadata etc. are met).
> https://github.com/opengisch/qfieldsync/blob/master/.travis.yml#L27
> It also only packages a sub-folder with the plugin, so scripts for ci
> etc that live outside this folder are not packaged.
> Hope that helps :)
> Matthias
> On 03/11/2017 10:12 PM, Magnus Homann wrote:
>> Hello, currently I tag my plugin code in git, and extract and build a
>> zip-file which is uploaded to plugin repo.
>> The Makefile that plugin_builder is supplyng, also have an option to zip
>> locally deployed files for later upload.
>> I prefer to packaged directly from tag in git, but then every file that
>> is in git will be packaged!
>> Have anyone made a mixed approach, packaging directly from a git tag,
>> but only a sub-set of the files?
>> /Magnus
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
