[QGIS-Developer] Bookmarks severely broken. Unusable?
Patrick Dunford enzedrailmaps at gmail.com
Tue Nov 28 20:57:44 PST 2017
I thought it would only create one in master, but when I quit and
reopened the project it had three bookmarks in it.
On 29/11/17 01:40, Richard Duivenvoorde wrote:
> Hi Yves,
> I have all kind of strange behaviours. As said: in master I can only
> create one bookmark. And 'In Project' I cannot check.
> But in 2.18.14 (only 2.18 I have) it is behaving strange too, looks like
> it is depending on if you opening an existing project or not???
> - I CAN check the check-boxes if I load an existing project
> BUT the bookmark checked moves to the bottom then (sorting on??)
> - I can NOT check the checkbox when I create a new project, then load
> some data, save the project and add a bookmark.
> - some project end up with a 0 srid (and are not usable anymore after that)
> - after opening an existing project I can all at a sudden check the
> check-boxes again (from other projects?), but IF I check those, I
> actually delete them from my global bookmarks????
> Apparently the 'In Project' means something like: save it in the
> project, BUT remove it from the global bookmarks?
> At least to me the behavior of all this is very counter-intuitive :-(
> 2.18, I do not care too much about it, but in Master it should work (and
> preferably work intuitive :-)  )...
> Regards,
> Richard
> On 28-11-17 09:22, Yves Jacolin wrote:
>> Hi,
>> I did a quick test in my 2.18.11 instance of QGIS:
>> * open an existing project
>> * zoom somewhere and add a new bookmark, check "in project" checkbox
>> * close the project, open a blank new project, do something
>> * open again the previous project and test the spatial bookmark
>> All worked as expected. I zoomed in the bookmark location and the "in
>> project" bookmark disappear in a new project.
>> Y.
>> Le 28/11/2017 à 09:17, Richard Duivenvoorde a écrit :
>>> Hi devs,
>>> just a head up that currently (with me) the Spatial Bookmarks are
>>> severely broken, both in master and 2.18.
>>> Stuff which should have been introduced:
>>> https://github.com/qgis/QGIS/pull/2661
>>> do not work with me here locally.
>>> Not even the basic adding of one bookmark.
>>> Other issues:
>>> https://issues.qgis.org/projects/qgis/search?utf8=%E2%9C%93&issues=1&q=bookmark
>>> Can people confirm?
>>> Though not that important in my view, I do not think we should ship
>>> current implementation in a 3.0
>>> Regards,
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
