[QGIS-Developer] Processing modeler GUI unusable in KDE / Plasma
Andreas Neumann a.neumann at carto.net
Thu Nov 30 00:14:57 PST 2017
Hi Etienne and Nyall,
Indeed - removing the file "qgis_customwidgets.py" from
/usr/lib/python3/dist-packages/PyQt5/uic/widget-plugins brought the
Processing modeler back to normal!
Cool!
So now we at least do know that this is the culprit.
Thanks,
Andreas
On 2017-11-30 09:02, Etienne Trimaille wrote:
> I got the problem too for many months even if it was disabled in the cmake.
> I needed to remove the qgis_customwidgets.py in the site-package folder of Python
> Maybe a `locate qgis_customwidgets.py` might help?
> 2017-11-30 8:37 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
> Hi Nyall,
> I reverted 5dce8edb
> and built with custom widgets enabled.
> Unfortunately, still the same problem.
> Thanks,
> Andreas
> On 30.11.2017 08:09, Nyall Dawson wrote:
> On 30 November 2017 at 16:39, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Mathieu,
> Thanks for your efforts! I just tested it - unfortunately, your commit does
> not solve my issue.
> I also tested with a new virgin user profile to make sure there isn't some
> old setting causing the troubles.
> Custom widgets support is also not enabled. Can you try:
> - revert https://github.com/qgis/QGIS/commit/5dce8edb [1]
> - build with custom widgets enabled and installed
> I want to rule out the custom widgets, and I suspect just switching
> them off in the build isn't enough to clean up the remnants of them.
> Nyall
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer [2]
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer [2]
Links:
[1] https://github.com/qgis/QGIS/commit/5dce8edb
[2] https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171130/c54aebf4/attachment.html>
More information about the QGIS-Developer mailing list
