[QGIS-Developer] MSSQL driver not found & Can't open lib 'SQL Server' - QGIS 2.18 LTR on Debian
kimaidou kimaidou at gmail.com
Wed Dec 5 11:37:41 PST 2018
Thanks for your answers. I managed to connect with QGIS MSSQL native
provider under my Debian box with the following steps
https://gist.github.com/mdouchin/64f7733a3c4ecfe441f65d5529351a30
I have a weird behaviour. For some layers, QGIS Desktop cannot display the
features attributes : the attribute table is empty, and the identify tool
returns no feature. BUT I can see the points in my map, so QGIS can query
the geography field from the database. For some other layers, wich seems
identical (same structure for example), I can see the attributes (full
attribute table and identify OK)
Have anyone seen this behaviour before ?
Cheers
Michaël
Le lun. 19 nov. 2018 à 00:12, Nyall Dawson <nyall.dawson at gmail.com> a
écrit :
> On Sat, 17 Nov 2018 at 02:01, kimaidou <kimaidou at gmail.com> wrote:
> > Hi all,
> > I am trying to connect to a MSSQL server from a QGIS installed in a
> Linux Debian Jessie computer.
> > I have checked that the credentials are ok with the mssql-client from
> Microsoft:
> > mssql-cli -S myserver -U carto -P ******* -d MyBase
> > I installed the following packages from debian and Microsoft repos :
> > curl https://packages.microsoft.com/keys/microsoft.asc | apt-key add -
> > curl https://packages.microsoft.com/config/debian/8/prod.list  >
> /etc/apt/sources.list.d/mssql-release.list
> > apt-get update
> > ACCEPT_EULA=Y apt-get install -y mssql-cli unixodbc-dev mssql-tools
> msodbcsql17 msodbcsql odbcinst libqt4-sql-tds libqt4-sql-odbc
> > When I open QGIS and try to set up a connection, I use not DSN, and I
> put my server "myserver" as the host. I add the user and password.
> > Then try to list the databases, but I get this error
> > [unixODBC][Driver Manager]Can't open lib 'SQL Server' : file not found
> This is all super-fragile. (Just another symptom of SQL Server's
> inferiority IMO).
> Have a look at
> https://github.com/qgis/QGIS/blob/master/.ci/travis/linux/docker-build-test.sh#L128
> for how the Travis testing environment sets up a connection, there may
> be some clues there.
> Nyall
> > I tested with
> > root at carto:~# odbcinst -j
> > unixODBC 2.3.1
> > DRIVERS............: /etc/odbcinst.ini
> > SYSTEM DATA SOURCES: /etc/odbc.ini
> > FILE DATA SOURCES..: /etc/ODBCDataSources
> > USER DATA SOURCES..: /root/.odbc.ini
> > SQLULEN Size.......: 8
> > SQLLEN Size........: 8
> > SQLSETPOSIROW Size.: 8
> > So I checked /etc/odbcinst.ini which seems ok
> > root at carto:~# cat /etc/odbcinst.ini
> > [ODBC Driver 17 for SQL Server]
> > Description=Microsoft ODBC Driver 17 for SQL Server
> > Driver=/opt/microsoft/msodbcsql17/lib64/libmsodbcsql-17.2.so.0.1
> > UsageCount=1
> > [ODBC Driver 13 for SQL Server]
> > Description=Microsoft ODBC Driver 13 for SQL Server
> > Driver=/opt/microsoft/msodbcsql/lib64/libmsodbcsql-13.1.so.9.2
> > UsageCount=1
> > Should I install more packages ?  Any help appreciated.
> > Regards,
> > Michaël
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181205/be6a22dd/attachment.html>
More information about the QGIS-Developer mailing list
