[QGIS-Developer] MSSQL driver not found & Can't open lib 'SQL Server' - QGIS 2.18 LTR on Debian
Nyall Dawson nyall.dawson at gmail.com
Wed Dec 5 14:55:32 PST 2018
On Thu, 6 Dec 2018 at 05:37, kimaidou <kimaidou at gmail.com> wrote:
> Thanks for your answers. I managed to connect with QGIS MSSQL native provider under my Debian box with the following steps
> https://gist.github.com/mdouchin/64f7733a3c4ecfe441f65d5529351a30
> I have a weird behaviour. For some layers, QGIS Desktop cannot display the features attributes : the attribute table is empty, and the identify tool returns no feature. BUT I can see the points in my map, so QGIS can query the geography field from the database. For some other layers, wich seems identical (same structure for example), I can see the attributes (full attribute table and identify OK)
Sounds like an issue with fetching by primary key/feature ID. Is there
any difference between the primary key setup on these tables vs the
ones which work?
Nyall
> Have anyone seen this behaviour before ?
> Cheers
> Michaël
> Le lun. 19 nov. 2018 à 00:12, Nyall Dawson <nyall.dawson at gmail.com> a écrit :
>> On Sat, 17 Nov 2018 at 02:01, kimaidou <kimaidou at gmail.com> wrote:
>> > Hi all,
>> > I am trying to connect to a MSSQL server from a QGIS installed in a Linux Debian Jessie computer.
>> > I have checked that the credentials are ok with the mssql-client from Microsoft:
>> > mssql-cli -S myserver -U carto -P ******* -d MyBase
>> > I installed the following packages from debian and Microsoft repos :
>> > curl https://packages.microsoft.com/keys/microsoft.asc | apt-key add -
>> > curl https://packages.microsoft.com/config/debian/8/prod.list  > /etc/apt/sources.list.d/mssql-release.list
>> > apt-get update
>> > ACCEPT_EULA=Y apt-get install -y mssql-cli unixodbc-dev mssql-tools msodbcsql17 msodbcsql odbcinst libqt4-sql-tds libqt4-sql-odbc
>> > When I open QGIS and try to set up a connection, I use not DSN, and I put my server "myserver" as the host. I add the user and password.
>> > Then try to list the databases, but I get this error
>> > [unixODBC][Driver Manager]Can't open lib 'SQL Server' : file not found
>> This is all super-fragile. (Just another symptom of SQL Server's
>> inferiority IMO).
>> Have a look at https://github.com/qgis/QGIS/blob/master/.ci/travis/linux/docker-build-test.sh#L128
>> for how the Travis testing environment sets up a connection, there may
>> be some clues there.
>> Nyall
>> > I tested with
>> > root at carto:~# odbcinst -j
>> > unixODBC 2.3.1
>> > DRIVERS............: /etc/odbcinst.ini
>> > SYSTEM DATA SOURCES: /etc/odbc.ini
>> > FILE DATA SOURCES..: /etc/ODBCDataSources
>> > USER DATA SOURCES..: /root/.odbc.ini
>> > SQLULEN Size.......: 8
>> > SQLLEN Size........: 8
>> > SQLSETPOSIROW Size.: 8
>> > So I checked /etc/odbcinst.ini which seems ok
>> > root at carto:~# cat /etc/odbcinst.ini
>> > [ODBC Driver 17 for SQL Server]
>> > Description=Microsoft ODBC Driver 17 for SQL Server
>> > Driver=/opt/microsoft/msodbcsql17/lib64/libmsodbcsql-17.2.so.0.1
>> > UsageCount=1
>> > [ODBC Driver 13 for SQL Server]
>> > Description=Microsoft ODBC Driver 13 for SQL Server
>> > Driver=/opt/microsoft/msodbcsql/lib64/libmsodbcsql-13.1.so.9.2
>> > UsageCount=1
>> > Should I install more packages ?  Any help appreciated.
>> > Regards,
>> > Michaël
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
