[QGIS-Developer] PyQgis QgsCoordinateTransform constructor?
Matthias Kuhn matthias at opengis.ch
Tue Jan 9 07:32:59 PST 2018
Hi
On 01/09/2018 03:38 PM, Alessandro Pasotti wrote:
> On Tue, Jan 9, 2018 at 3:14 PM, Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
>     Hi Alessandro,
>     Thanks for your information.
>     I just want to hear other core devs' opinions if this would be
>     useful for QGIS.ORG <http://QGIS.ORG>. QGIS.ORG <http://QGIS.ORG>
>     infrastructure is already complex and mainly only Jürgen, Richard
>     and partially Tim understand the infrastructure partially. If we
>     start something new I would like to see a long-term commitment from
>     someone to maintain it (lets say at least for the upcoming year from
>     the start on).
> I totally agree, I'm not pushing for AWS expecially because the
> nightlies are still available, just trying to offer a solution to a
> problem, and the solution is still available (as long as Boundless
> doesn't switch off the nightlies), when I was in Boundless we went
> through the same problem 2 years ago, we tried automated docker builds
> and they timed out (like Denis said) so we went for AWS and it has been
> working reliably for 2 years, it may just require small adjustments when
> new dependencies are added (like with Qt 9.1 for 3D).
> BTW, I believe that a publicly available nightly docker for Python
> plugins Travis-CI testing is beneficial for everybody and increases
> plugins quality, I'm just sad when I see people reinventing the wheel.
> I would be happier if a company committed to sponsor and long-term
> maintain this part of the infrastructure, today it's up and running and
> QGIS master nightly docker images for CI are generated and publicly
> available, but we don't know about tomorrow.
I would much appreciate if we could setup this kind of infrastructure in
a way that it's maintainable via scripts (in the qgis repo or another
one). Just like with a .travis.yml file and similar.
This will allow to spread the load between different developers. E.g.
when new dependencies are added (see libzip for auxiliary storage and
similar, qca, ...), we shouldn't need a maintainer to update this dep,
the one opening the pull request should be able to do this himself.
I guess AWS would be fine for this kind of setup where we only have a
minimal maintenance effort directly on the infrastructure (as opposed to
managing physical servers or virtual machines).
Matthias
More information about the QGIS-Developer mailing list
