[QGIS-Developer] QGIS3 Processing Modeler - some bugs encountered
kimaidou kimaidou at gmail.com
Fri Jan 19 00:26:01 PST 2018
Dear devs,
I am looking at Processing for QGIS3, and would like to share some bugs I
discovered while playing with models. I have not found related issues in
the hub. I will add them after some feedback. Please point me the the
issues if they do exists in Redmine
* Number input is not proposed in algorithms. For example, after adding an
input of type Number, you cannot anymore use this input as a value for the
buffer size in the QGIS fixed buffer alg : no combobox is shown to the
user, just a standard text input.
* Grid alg : the user can choose the extent of one of the vector layers (
inputs or results of alg), bug when you run the model, the extent is empty
and the grid alg failed.
Regards,
Michaƫl
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180119/adca7889/attachment.html>
More information about the QGIS-Developer mailing list
