[QGIS-Developer] osgeo4w's qgis-dev package broken, proj_7_0.dll missing
Nyall Dawson nyall.dawson at gmail.com
Thu Dec 5 15:06:13 PST 2019
On Fri, 6 Dec 2019 at 07:54, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi,
> On Thu, 05. Dec 2019 at 11:22:35 +0000, Pedro Venâncio wrote:
> > But I believe that should be fixed in the next build.
> Yes, the rebuild has picked the new proj up.
> Rhere also a new qgis-ltr now - and new standalones for 3.4.13.
> As that also required updates to the build scripts in the release branch -
> tomorrows 3.4.14 should be almost the same - except for some translations…
Testing 3.4.13, it looks like you've successfully found a solution to
use gdal < 3 and proj < 6 for the 3.4 build?
Great work!!
Nyall
More information about the QGIS-Developer mailing list
