[QGIS-Developer] osgeo4w's qgis-dev package broken, proj_7_0.dll missing
Nathan Woodrow
madmanwoo at gmail.com
Thu Dec 5 15:08:41 PST 2019
Great work! Thanks for all your hard work Jürgen it's really appreciated.
On Fri, Dec 6, 2019 at 9:06 AM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Fri, 6 Dec 2019 at 07:54, Jürgen E. Fischer <jef at norbit.de> wrote:
> > Hi,
> > On Thu, 05. Dec 2019 at 11:22:35 +0000, Pedro Venâncio wrote:
> > > But I believe that should be fixed in the next build.
> > Yes, the rebuild has picked the new proj up.
> > Rhere also a new qgis-ltr now - and new standalones for 3.4.13.
> > As that also required updates to the build scripts in the release branch
> > tomorrows 3.4.14 should be almost the same - except for some
> translations…
> Testing 3.4.13, it looks like you've successfully found a solution to
> use gdal < 3 and proj < 6 for the 3.4 build?
> Great work!!
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191206/c5cbd5e5/attachment.html>
