[QGIS-Developer] Issues installing on ubuntu 19.10
Jürgen E. Fischer jef at norbit.de
Sat Nov 16 12:37:27 PST 2019
Hi Tim,
On Sat, 16. Nov 2019 at 20:07:24 +0000, Tim Sutton wrote:
> Ah thanks - I was following the notes on the ubuntu section of http://download.qgis.org
Ok, eoan should be listed, but wasn't.  If it had been, it would not have had a
"yes" in the "Also available based on ubuntugis-unstable dependencies?"
column.
> "For Ubuntu we also have extra packages in a separate repository that are
> based on ubuntugis, which holds more uptodate versions of other GIS packages
> than Ubuntu itself. If you want those you also need to include
> ubuntugis-unstable ppa in your /etc/apt/sources.list file (see ubuntugis
> documentation)."
> .... so if I understand that correctly I needed to add ubuntugis-unstable?
The linked documentation says 'The Ubuntu GIS packages are only available for
the Ubuntu LTS releases which haven't gone end-of-life yet.'.  So only for
xenial and bionic.
For all others you can install from qgis.org/ubuntu (or /debian which is the
same repo.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191116/04ba56a9/attachment.sig>
More information about the QGIS-Developer mailing list
