[QGIS-Developer] Issues installing on ubuntu 19.10
Tim Sutton
tim at kartoza.com
Sat Nov 16 12:54:23 PST 2019
Thanks Juergen - all working now - though it is running against GDAL 2.4.2. I was nerdily hoping to get GDAL 3.x in the process :-p
Regards
Tim
QGIS version
3.10.0-A Coruña
QGIS code revision
6c816b4204 (https://link.getmailspring.com/link/8782727E-0A75-495D-AFFB-00A4ACD55110@getmailspring.com/0?redirect=https%3A%2F%2Fgithub.com%2Fqgis%2FQGIS%2Fcommit%2F6c816b4204&recipient=cWdpcy1kZXZlbG9wZXJAbGlzdHMub3NnZW8ub3Jn)
Compiled against Qt
5.12.4
Running against Qt
5.12.4
Compiled against GDAL/OGR
2.4.2
Running against GDAL/OGR
2.4.2
Compiled against GEOS
3.7.2-CAPI-1.11.2
Running against GEOS
3.7.2-CAPI-1.11.2 b55d2125
Compiled against SQLite
3.29.0
Running against SQLite
3.29.0
PostgreSQL Client Version
11.5 (Ubuntu 11.5-1)
SpatiaLite Version
4.3.0a
QWT Version
6.1.4
QScintilla2 Version
2.10.4
Compiled against PROJ
5.2.0
Running against PROJ
Rel. 5.2.0, September 15th, 2018
OS Version
Ubuntu 19.10
Active python plugins
Mergin;
db_manager;
MetaSearch;
processing
On Nov 16 2019, at 8:37 pm, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Tim,
> On Sat, 16. Nov 2019 at 20:07:24 +0000, Tim Sutton wrote:
> > Ah thanks - I was following the notes on the ubuntu section of http://download.qgis.org
> Ok, eoan should be listed, but wasn't. If it had been, it would not have had a
> "yes" in the "Also available based on ubuntugis-unstable dependencies?"
> column.
> > "For Ubuntu we also have extra packages in a separate repository that are
> > based on ubuntugis, which holds more uptodate versions of other GIS packages
> > than Ubuntu itself. If you want those you also need to include
> > ubuntugis-unstable ppa in your /etc/apt/sources.list file (see ubuntugis
> > documentation)."
> > .... so if I understand that correctly I needed to add ubuntugis-unstable?
> The linked documentation says 'The Ubuntu GIS packages are only available for
> the Ubuntu LTS releases which haven't gone end-of-life yet.'. So only for
> xenial and bionic.
> For all others you can install from qgis.org/ubuntu (or /debian which is the
> same repo.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden https://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191116/78afe0ac/attachment-0001.html>
