[QGIS-Developer] SQL in graphic modeller - Reg
Karthikeyan M kalam1993 at gmail.com
Fri Aug 14 04:23:12 PDT 2020
Hi ,
I'm learning graphic modeller in QGis3. Earlier I used to select only 3
columns ( from 73 coloumn) of attributes by using sql query in DB manager.
I want to create a  model for that. Is there anyway I can use that sql
query to extract particular coloumn from shape files using Graphic modeller
Expecting your reply
Regards,
Karthikeyan M
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200814/61b53b10/attachment.html>
More information about the QGIS-Developer mailing list
