[QGIS-Developer] use qt 5.10 for CI tests
BELGACEM NEDJIMA gb_nedjima at esi.dz
Thu Aug 27 06:12:48 PDT 2020
Hi Matthias,
Yes, I wanted to run the CI tests on a version >= Qt5.10 because if I
disable shadow rendering for <=Qt5.9, it will bypass all the tests and may
add some bugs into the codebase.
On Thu, Aug 27, 2020, 1:45 PM Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Peter,
> I don't see a problem to conditionally disable shadows for Qt <= 5.10, we
> also have other conditions depending on the Qt version in other parts of
> the codebase.
> Is there a hidden question how to go about testing this in CI? If yes, I'd
> say the best approach would indeed be to enable tests for Qt 5.14.
> Best regards
> Matthias
> On Thu, Aug 27, 2020 at 1:58 PM Peter Petrik <
> peter.petrik at lutraconsulting.co.uk> wrote:
>> Hi,
>> CI on travis runs with qt 5.9 and for
>> https://github.com/qgis/QGIS/pull/38448 we need to have qt 5.10+. In 5.9
>> the 3d shadow rendering does not work correctly and since Windows, Mac and
>> latest Linux distributions run on newer qt's I do not see a reason to spend
>> considerable time to fix the 3d shadows for qt 5.9. I was thinking to
>> disable this feature for builds with qt 5.9.I see the qt5.14 build in the
>> repository, but that one is without tests.
>> I am wondering how to best approach this?
>> Thanks,
>> Peter
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200827/fdec66de/attachment.html>
More information about the QGIS-Developer mailing list
