[QGIS-Developer] use qt 5.10 for CI tests
Matthias Kuhn matthias at opengis.ch
Thu Aug 27 10:44:07 PDT 2020
Hi Belgacem,
It would be very good to have tests indeed !
If you have them ready, it should be straightforward to enable these on the
qt 5.14 build.
Best regards
Matthias
On Thu, Aug 27, 2020 at 3:13 PM BELGACEM NEDJIMA <gb_nedjima at esi.dz> wrote:
> Hi Matthias,
> Yes, I wanted to run the CI tests on a version >= Qt5.10 because if I
> disable shadow rendering for <=Qt5.9, it will bypass all the tests and may
> add some bugs into the codebase.
> On Thu, Aug 27, 2020, 1:45 PM Matthias Kuhn <matthias at opengis.ch> wrote:
>> Hi Peter,
>> I don't see a problem to conditionally disable shadows for Qt <= 5.10, we
>> also have other conditions depending on the Qt version in other parts of
>> the codebase.
>> Is there a hidden question how to go about testing this in CI? If yes,
>> I'd say the best approach would indeed be to enable tests for Qt 5.14.
>> Best regards
>> Matthias
>> On Thu, Aug 27, 2020 at 1:58 PM Peter Petrik <
>> peter.petrik at lutraconsulting.co.uk> wrote:
>>> Hi,
>>> CI on travis runs with qt 5.9 and for
>>> https://github.com/qgis/QGIS/pull/38448 we need to have qt 5.10+. In
>>> 5.9 the 3d shadow rendering does not work correctly and since Windows, Mac
>>> and latest Linux distributions run on newer qt's I do not see a reason to
>>> spend considerable time to fix the 3d shadows for qt 5.9. I was thinking to
>>> disable this feature for builds with qt 5.9.I see the qt5.14 build in the
>>> repository, but that one is without tests.
>>> I am wondering how to best approach this?
>>> Thanks,
>>> Peter
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200827/a69de0b1/attachment.html>
More information about the QGIS-Developer mailing list
