[QGIS-Developer] Travis failing in QGIS-Documentation
Denis Rouzaud denis.rouzaud at gmail.com
Fri Aug 28 00:26:54 PDT 2020
Le ven. 28 août 2020 à 09:12, matteo <matteo.ghetta at gmail.com> a écrit :
> Hi Denis,
> > The Docker has indeed been fixed for about 2 days (and PyQGIS API docs
> > are being built again since this morning).
> > Regarding the segmentation you mention, I don't see this is related to
> > the Docker image.
> > It's a bit hard to know from this what is happening from the log.
> > Can you run it locally?
> I get some problems running tests locally, see
> https://lists.osgeo.org/pipermail/qgis-developer/2020-August/062037.html
where is start_qgis defined? I don't find it in QGIS sources.
> I also noticed that the docker is almost 10GB, is this size normal?
No. Looking on docker hub, the image is around 1.8gb (still a lot though)
https://hub.docker.com/repository/docker/qgis/qgis/tags?page=1
> If you have some suggestion to solve this problem I'll update also the
> documentation (that is right now outdated except for the docker part).
> Cheers and thanks
> Matteo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200828/e620d5fe/attachment-0001.html>
More information about the QGIS-Developer mailing list
