[QGIS-Developer] ~/.local/share populated with QGIS files for each test
Sandro Santilli strk at kbt.io
Sat Feb 1 01:20:03 PST 2020
I found out that my `ctest` runs, under QGIS build dir, result
in a directory created under ~/.local/share/ having the same
name as the source python script the run test is coming from.
Hundreds of such directories.
Is this expected or is it a problem with my setup ?
--strk;
More information about the QGIS-Developer mailing list
