[QGIS-Developer] ~/.local/share populated with QGIS files for each test
Matthias Kuhn matthias at opengis.ch
Sat Feb 1 01:24:44 PST 2020
Expected.
But not by design or desired.
Matthias
On 2/1/20 10:20 AM, Sandro Santilli wrote:
> I found out that my `ctest` runs, under QGIS build dir, result
> in a directory created under ~/.local/share/ having the same
> name as the source python script the run test is coming from.
> Hundreds of such directories.
> Is this expected or is it a problem with my setup ?
> --strk;
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
