[QGIS-Developer] QGIS Server: warnings vs info
David Marteau dmarteau at 3liz.com
Tue Feb 4 00:26:33 PST 2020
Yes, there is some log messages that are not output with the correct log
level, should be fixed in near future.
Le 03/02/2020 à 19:26, Tomas Straupis a écrit :
> Hello
>    While reading QGIS Server logs I wonder if this has some idea or is an error.
>    After QGIS Server starts running ok I assume it is normal to change
> QGIS_SERVER_LOG_LEVEL to 1 - do not show INFO type messages which
> quickly go into hundreds of megs of text on a busy server.
>    But if I understand correctly, some messages go into incorrect
> levels thus both adding unnecessary info messages as well as hiding
> important info.
>    For example:
>    1. Excessive warning level messages include:
>    * formatString is: image/png (server/qgsrequesthandler.cpp)
>    * Adding service SampleService 1.0, WCS 1.0.0 etc. etc.
> (servce/qgsserviceregistry.cpp)
>    2. Missing important info message:
>    * <ServiceExceptionError ...>The layer 'ABC' does not
> exist.</ServiceException> (services/wms/qgswmsserviceexception.h)
>    Am I missing something?
>    Thank you
David Marteau
Responsable Infrastructure
www.3liz.com <http://www.3liz.com>
*Tel*. 06 63 02 89 83
*Bureau*
31, rue de l'Argenterie
34000 Montpellier
*Siège social*
73, allée Kleber
Boulevard de Strasbourg
34000 Montpellier
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200204/2b26f06f/attachment.html>
More information about the QGIS-Developer mailing list
