[QGIS-Developer] QGIS Server: warnings vs info
Paul Blottiere blottiere.paul at gmail.com
Tue Feb 4 00:10:03 PST 2020
Hello Tomas,
 > Am I missing something?
No you're right. I'm taking a look to fix that.
Thanks for raising the issue!
Regards.
Paul Blottiere
On 2/3/20 7:26 PM, Tomas Straupis wrote:
> Hello
>    While reading QGIS Server logs I wonder if this has some idea or is an error.
>    After QGIS Server starts running ok I assume it is normal to change
> QGIS_SERVER_LOG_LEVEL to 1 - do not show INFO type messages which
> quickly go into hundreds of megs of text on a busy server.
>    But if I understand correctly, some messages go into incorrect
> levels thus both adding unnecessary info messages as well as hiding
> important info.
>    For example:
>    1. Excessive warning level messages include:
>    * formatString is: image/png (server/qgsrequesthandler.cpp)
>    * Adding service SampleService 1.0, WCS 1.0.0 etc. etc.
> (servce/qgsserviceregistry.cpp)
>    2. Missing important info message:
>    * <ServiceExceptionError ...>The layer 'ABC' does not
> exist.</ServiceException> (services/wms/qgswmsserviceexception.h)
>    Thank you
More information about the QGIS-Developer mailing list
