[QGIS-Developer] MS SQL Support - versions?
Alexander Bruy alexander.bruy at gmail.com
Thu Feb 6 08:29:38 PST 2020
Pedro,
QGIS provider uses QtSql (namely QODBC) to access MSSQL, so your link
is not relevant in this case.
Andreas,
not 100% sure, but you should be able to use any MSSQL version, just
need to install proper ODBC drivers
for it. On *nix systems, you will need a FreeTDS driver.
чт, 6 лют. 2020 о 18:21 Pedro Venâncio <pedrongvenancio at gmail.com> пише:
> Hi Andreas,
> From https://gdal.org/drivers/vector/mssqlspatial.html
> This driver implements support for access to spatial tables in Microsoft SQL Server 2008+ which contains the geometry and geography data types to represent the geometry columns.
> Best regards,
> Pedro
> Andreas Neumann <a.neumann at carto.net> escreveu no dia quinta, 6/02/2020 à(s) 16:10:
>> Hi,
>> Is there information what versions of MS SQL-Server are supported by QGIS as a client?
>> Thanks,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
More information about the QGIS-Developer mailing list
