[QGIS-Developer] MS SQL Support - versions?
Pedro Venâncio pedrongvenancio at gmail.com
Thu Feb 6 08:35:18 PST 2020
Oh, thanks Alexander, I thought it was using the gdal driver.
Best regards,
Pedro
Alexander Bruy <alexander.bruy at gmail.com> escreveu no dia quinta, 6/02/2020
à(s) 16:29:
> Pedro,
> QGIS provider uses QtSql (namely QODBC) to access MSSQL, so your link
> is not relevant in this case.
> Andreas,
> not 100% sure, but you should be able to use any MSSQL version, just
> need to install proper ODBC drivers
> for it. On *nix systems, you will need a FreeTDS driver.
> чт, 6 лют. 2020 о 18:21 Pedro Venâncio <pedrongvenancio at gmail.com> пише:
> > Hi Andreas,
> > From https://gdal.org/drivers/vector/mssqlspatial.html
> > This driver implements support for access to spatial tables in Microsoft
> SQL Server 2008+ which contains the geometry and geography data types to
> represent the geometry columns.
> > Best regards,
> > Pedro
> > Andreas Neumann <a.neumann at carto.net> escreveu no dia quinta, 6/02/2020
> à(s) 16:10:
> >> Hi,
> >> Is there information what versions of MS SQL-Server are supported by
> QGIS as a client?
> >> Thanks,
> >> Andreas
> >> _______________________________________________
> >> QGIS-Developer mailing list
> >> QGIS-Developer at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200206/adf25db4/attachment.html>
More information about the QGIS-Developer mailing list
