[QGIS-Developer] QGIS 3.10.2 start issue
Martin Steiger Martin.Steiger at zg.ch
Fri Feb 14 05:03:24 PST 2020
Hello,
I hope I write to the correct address with my request.
In the "Kantonsverwaltung Zug" we use QGIS since version 2.16 in the department of geoinformation. We always used the following command to start QGIS:
"C:\Program Files\QGIS_3_8_ZANZIBAR\bin\nircmd.exe" exec hide C:\Program Files\QGIS_3_8_ZANZIBAR\bin\qgis.bat
(Yes, we install it in a custom named folder)
It always worked out fine and QGIS started without any issues. However, in version 3.10.2 this does not work out, because the file qgis.bat does not exist. I found the file "C:\Program Files\QGIS_3_10_2_Coruna\bin\qgis-bin.exe" and tried to start it.
Unfortunately I get an error message (see attachment). If I start the file "C:\Program Files\QGIS_3_10_2_Coruna\bin\qgis-bin-g7.exe" I get the same behaviour. I think it's a little bit odd that the mentioned file "C:\Program Files\QGIS_3_10_2_Coruna\bin\qgis-bin.env" doesn't even exist in the file system...
Can you help me out with this issue? Or is there a way you would recommend to correctly start QGIS?
We use Windows 10 Build 1809 with the newest windows updates.
Best Regards
Martin Steiger
Finanzdirektion Kanton Zug
Amt für Informatik und Organisation (AIO) des Kantons Zug
Martin Steiger
Computer scientist in apprenticeship
Aabachstrasse 1
6300 Zug
Switzerland
T +41 41 728 51 29
martin.steiger at zg.ch<mailto:martin.steiger at zg.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200214/02bed30d/attachment-0001.html>
Type: image/png
Desc: QGIS_3.10.2_error_message.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200214/02bed30d/attachment-0001.png>
More information about the QGIS-Developer mailing list
