[QGIS-Developer] QGIS 3.10.2 start issue
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Sat Feb 15 13:00:43 PST 2020
Hi Martin -
I don't know how you have installed QGIS. Probably a simple xcopy.
However, the error message states:
"Look in /path_to_directory_for_QGIS_binary/\qgis-bin.env for correct paths"
This file - qgis-bin.env - has to be present in the same directory as
qgis-bin.exe - contains a lot of setup information previously contained
in qgis.bat.
And it has to be configured corecctly. It's a text file, so you can edit
the file with a simple text editor like notepad.
A small sample from my own .env file (where qgis-bin.exe is located in
c:\ocgeo4win64\bin:
/PATH=C:\OSGEO4~1\apps\qgis\bin;C:\OSGEO4~1\apps\Python37;C:\OSGEO4~1\apps\Python37\Scripts//...
blah blah
/C:\OSGEO4~1\ /is the "DOS old-style 8.3" name for /C:\OSGeo4W64\
All these path names in the .env file has to be configured correctly
regarding your home-path for QGIS
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Civ.Ing
AestasGIS Denmark
Den 14-02-2020 kl. 14:03 skrev Martin Steiger:
> Hello,
> I hope I write to the correct address with my request.
> In the "Kantonsverwaltung Zug" we use QGIS since version 2.16 in the
> department of geoinformation. We always used the following command to
> start QGIS:
> "C:\Program Files\QGIS_3_8_ZANZIBAR\bin\nircmd.exe" exec hide
> C:\Program Files\QGIS_3_8_ZANZIBAR\bin\qgis.bat
> (Yes, we install it in a custom named folder)
> It always worked out fine and QGIS started without any issues.
> However, in version 3.10.2 this does not work out, because the file
> qgis.bat does not exist. I found the file "C:\Program
> Files\QGIS_3_10_2_Coruna\bin\qgis-bin.exe" and tried to start it.
> Unfortunately I get an error message (see attachment). If I start the
> file "C:\Program Files\QGIS_3_10_2_Coruna\bin\qgis-bin-g7.exe"I get
> the same behaviour. I think it’s a little bit odd that the mentioned
> file "C:\Program Files\QGIS_3_10_2_Coruna\bin\qgis-bin.env"doesn’t
> even exist in the file system…
> Can you help me out with this issue? Or is there a way you would
> recommend to correctly start QGIS?
> We use Windows 10 Build 1809 with the newest windows updates.
> Best Regards
> Martin Steiger
> Finanzdirektion Kanton Zug
> Amt für Informatik und Organisation (AIO) des Kantons Zug
> Martin Steiger
> Computer scientist in apprenticeship
> Aabachstrasse 1
> 6300 Zug
> Switzerland
> T +41 41 728 51 29
> martin.steiger at zg.ch <mailto:martin.steiger at zg.ch>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200215/9f733c58/attachment.html>
More information about the QGIS-Developer mailing list
