[QGIS-Developer] QGIS 3.10.2 start issue
Thomas Baumann rdbath.regiodata at gmail.com
Mon Feb 17 03:26:08 PST 2020
Hi Martin,
did you use the standalone installer or the OSGEO4W-Installer?
You can have a look if in your C:\Program Files\QGIS_3_10_2_Coruna\bin
folder if there exists a qgis.bat.tmpl file as template for the qgis.bat.
If so you can copy the file and rename it to qgis.bat. If not you can
create a qgis.bat with a content similar to this:
https://gist.githubusercontent.com/thbaumann/1550ba276b5c17f36edf9f91379dd81d/raw/795a657d10dcc9189f1d9331cec35382a2815db2/qgis.bat_template
(this bat file content is one for an OSGEO4W-Installation)
Afterwards you can open your cmd commandline("Eingabeaufforderung"),
navigate to C:\Program Files\QGIS_3_10_2_Coruna\bin and call "qgis.bat
--postinstall" to create the env file.
regards,
Thomas
Am Fr., 14. Feb. 2020 um 14:03 Uhr schrieb Martin Steiger <
Martin.Steiger at zg.ch>:
> Hello,
> I hope I write to the correct address with my request.
> In the "Kantonsverwaltung Zug" we use QGIS since version 2.16 in the
> department of geoinformation. We always used the following command to start
> QGIS:
> "C:\Program Files\QGIS_3_8_ZANZIBAR\bin\nircmd.exe" exec hide C:\Program
> Files\QGIS_3_8_ZANZIBAR\bin\qgis.bat
> (Yes, we install it in a custom named folder)
> It always worked out fine and QGIS started without any issues. However, in
> version 3.10.2 this does not work out, because the file qgis.bat does not
> exist. I found the file "C:\Program
> Files\QGIS_3_10_2_Coruna\bin\qgis-bin.exe" and tried to start it.
> Unfortunately I get an error message (see attachment). If I start the file "C:\Program
> Files\QGIS_3_10_2_Coruna\bin\qgis-bin-g7.exe" I get the same behaviour. I
> think it’s a little bit odd that the mentioned file "C:\Program
> Files\QGIS_3_10_2_Coruna\bin\qgis-bin.env" doesn’t even exist in the file
> system…
> Can you help me out with this issue? Or is there a way you would recommend
> to correctly start QGIS?
> We use Windows 10 Build 1809 with the newest windows updates.
> Best Regards
> Martin Steiger
> Finanzdirektion Kanton Zug
> Amt für Informatik und Organisation (AIO) des Kantons Zug
> Martin Steiger
> Computer scientist in apprenticeship
> Aabachstrasse 1
> 6300 Zug
> Switzerland
> T +41 41 728 51 29
> martin.steiger at zg.ch
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200217/e2c5426a/attachment.html>
More information about the QGIS-Developer mailing list
