[QGIS-Developer] Point cloud tests disabled
Sandro Santilli strk at kbt.io
Tue Feb 18 00:56:41 PST 2020
On Fri, Feb 14, 2020 at 08:43:35PM +0100, Matthias Kuhn wrote:
> Hi,
> The recently added point cloud tests had to be reverted today as they
> suddenly started to fail and flagged every pull request as broken.
> https://github.com/qgis/QGIS/pull/34474
> Here is a reference to a failing build
> https://travis-ci.org/qgis/QGIS/jobs/650344373#L997-L998
> It looks like the pointcloud module fails to build, probably because of an
> update of postgres in the underlying docker image (?). If someone knows how
> to fix these tests, that would be appreciated!
For the record: I'm tackling this in
  https://github.com/qgis/QGIS/pull/34500
--strk;
More information about the QGIS-Developer mailing list
