[QGIS-Developer] Point cloud tests disabled
Sandro Santilli strk at kbt.io
Wed Feb 19 03:01:44 PST 2020
On Tue, Feb 18, 2020 at 09:56:41AM +0100, Sandro Santilli wrote:
> On Fri, Feb 14, 2020 at 08:43:35PM +0100, Matthias Kuhn wrote:
> > Hi,
> > The recently added point cloud tests had to be reverted today as they
> > suddenly started to fail and flagged every pull request as broken.
> > https://github.com/qgis/QGIS/pull/34474
> > Here is a reference to a failing build
> > https://travis-ci.org/qgis/QGIS/jobs/650344373#L997-L998
> > It looks like the pointcloud module fails to build, probably because of an
> > update of postgres in the underlying docker image (?). If someone knows how
> > to fix these tests, that would be appreciated!
> For the record: I'm tackling this in
>   https://github.com/qgis/QGIS/pull/34500
For master branch the test was recovered, could someone please approve
the backport to 3.10 ?
https://github.com/qgis/QGIS/pull/34531
--strk;
More information about the QGIS-Developer mailing list
