[QGIS-Developer] PGSYSCONFDIR environmental variable use in QGIS Postgres service
Olivier Dalang olivier.dalang at gmail.com
Thu Feb 27 13:20:55 PST 2020
I think you have to name the file "pg_service.conf" not ".pg_service.conf"
when setting  PGSYSCONFDIR. It works well here.
By the way, these type of questions are better asked in qgis-user.
Cheers,
Olivier
On Thu, 27 Feb 2020 at 10:40, Jakob <jakob at lanstorp.com> wrote:
> I have a .pg_service.conf file with a Postgres connection use as a Service
> connection in QGIS dialog "Create a New PostGIS Connection", running on
> Windows 10.
> This works fine when the pg_service is placed in the folder
> "C:\Users\myuser\AppData\Roaming\Postgresql".
> Now to change the folder of the pg_service file I somewhere read that the
> folder is defined in environmental variable PGSYSCONFDIR, but setting a
> path
> in this variable does not make QGIS look in the new folder for the
> .pg_service.conf file. It still looks in the folder
> Do I misunderstand the meaning of PGSYSCONFDIR variable use in QGIS?
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200227/963e0f23/attachment.html>
More information about the QGIS-Developer mailing list
