[QGIS-Developer] Print Layouts and Atlas not following
Raymond Nijssen r.nijssen at terglobo.nl
Thu Jan 2 04:07:01 PST 2020
Did you check the "Controlled by Atlas" checkbox in the Map item properties?
On 02-01-2020 12:56, Richard Duivenvoorde wrote:
> Hi Devs,
> Wanted to show 'Atlas' functionality here to somebody, but... not
> working. Tried master and 3.10 on Linux and 3.6 on Windows.
> What I did:
> - open a WmS layer
> - create a shp file with 3 polygons
> - create a layouter with only a map item
> - create an atlas
> Output (whatever output I try: pdf or images) always end up as 3 the
> same pages (the view I had in the layouter).
> The Atlas does not 'follow' the 3 polygons...
> Do I miss something?
> Is it working with you?
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
