[QGIS-Developer] Print Layouts and Atlas not following
Richard Duivenvoorde rdmailings at duif.net
Thu Jan 2 04:17:36 PST 2020
Ah, duh...
Thanks Raymond, that is pretty hidden.... see screendump.
Would be cool to get a message like "hey, you are asking me to generate
an atlas but I do not have any map controlled by Map, should I use the
(only) map I have? Not sure if it is easy to check for this property...
Feature Request :-) ?
Regards,
On 02/01/2020 13.07, Raymond Nijssen wrote:
> Did you check the "Controlled by Atlas" checkbox in the Map item
> properties?
> On 02-01-2020 12:56, Richard Duivenvoorde wrote:
>> Hi Devs,
>> Wanted to show 'Atlas' functionality here to somebody, but... not
>> working. Tried master and 3.10 on Linux and 3.6 on Windows.
>> What I did:
>> - open a WmS layer
>> - create a shp file with 3 polygons
>> - create a layouter with only a map item
>> - create an atlas
>> Output (whatever output I try: pdf or images) always end up as 3 the
>> same pages (the view I had in the layouter).
>> The Atlas does not 'follow' the 3 polygons...
>> Do I miss something?
>> Is it working with you?
>> Regards,
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200102/55103bc9/attachment-0001.png>
More information about the QGIS-Developer mailing list
