[QGIS-Developer] icons for remove/delete actions
Raymond Nijssen r.nijssen at terglobo.nl
Sat Jan 4 23:00:21 PST 2020
Thank you Robert!
Interesting to read that pdf as well. However it doesn't contain
"traffic sign" icons, which are the ones I found mostly in QGIS.
So in short:
- Non-destructive removal (hide)
x Destructive removal (delete)
ø QGIS removal?
Kind regards,
Raymond
Terglobo
Fahrenheitstraat 1
5223 BJ 's-Hertogenbosch
The Netherlands
+31 (0) 6 25 31 49 83
On 04-01-2020 16:05, Robert Szczepanek wrote:
> Dear Raymond,
> The initial idea creating GIS icons set was to define generic actions.
> 1. Remove
> https://github.com/Cracert/GIS-icons/blob/master/24x24/layer-remove.png
> Non-destructive operation.
> You add a layer to composition, then you remove it.
> 2. Delete
> https://github.com/Cracert/GIS-icons/blob/master/24x24/layer-delete.png
> Destructive operation.
> You create a layer, then you delete it.
> More detailed description you can find in this article:
> https://ojs.cvut.cz/ojs/index.php/gi/article/view/2737
> Best regards,
> Robert
>> sob., 4 sty 2020 o 13:14 Raymond Nijssen <r.nijssen at terglobo.nl
>> <mailto:r.nijssen at terglobo.nl>> napisał(a):
>>     Many icons in QGIS have little shields specifying what kind of action
>>     they represents, like adding, editing and removing. For removing and
>>     deleting things, I found 3 different shields though, a cross, a
>> traffic
>>     sign and a minus.
>>     What is the logic for these 3? A difference in removing or
>> deleting or
>>     hiding maybe?
>>     Or is this just caused by QGIS's evolution? In that case, what
>>     should be
>>     the right shield to use now?
>>     See attached screenshot
>>     Thanks!
>>     Raymond
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
