[QGIS-Developer] Trigger atlas on another layer
Alexandre Neto senhor.neto at gmail.com
Thu Aug 5 08:56:10 PDT 2021
What do you mean by trigger atlas?
A quinta, 5/08/2021, 10:55, Andreas Neumann <a.neumann at carto.net> escreveu:
> Hi,
> I have two layers:
>    - layer 1 for editing
>    - layer 2 with joins, aggregates, etc. as a Postgis view prepared to
>    be used for an Atlas
> Both layers share the same primary keys.
> Question: could I trigger the atlas (of a selected single feature) from
> layer 2 from the form/table of layer 1?  With an action and some Python
> code? Are there Python code examples around on how I could achieve that?
> Reasoning: layer 2 is only a helper construct. The GIS operator is
> supposed to work with layer 1 and ideally the atlas could be triggered from
> layer 1, even though it is defined on layer 2.
> Thank you for any ideas,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210805/9b796189/attachment.html>
More information about the QGIS-Developer mailing list
